Production RCC-BIG2 | customizable BTO case | support for 280mm AIOs or Noctua NH-C14S
REVOCCASES
REVOCCASES
1,146
1,065
www.revoccases.com
@Nero look what came in for you - finally :p
Reactions: Nero and rfarmer
REVOCCASES
REVOCCASES
1,146
1,065
www.revoccases.com
just wanted to share one more version of the BIG2 which I made for myself:
  • GPU clearance: 340mm / 3 slots (67mm)
  • up to 6 case fans (5x 140x25mm & 1x 120x15mm)
  • 280mm AIO support
  • vertical or horizontal orientation
looks so empty with my tiny R9 Fury
still lots of space to put two more fans on the 280mm rad 😅
also the parts for htmyles came back...
I made two sets of each case, if someone would like to take one just let me know...
REVOCCASES
REVOCCASES
1,146
1,065
www.revoccases.com
I think my build is a bit overcooled...
R5 2600 with slight OC won't go over 50C and my R9 Fury stays well around 60C during benchmarking with all fans set to minimum RPM XD
Now looking forward to Nero's test results... :)
Reactions: eedev and robbee
nathanjaker
This project is awesome. Is there a version of the case that puts the 280mm rad opposite the GPU, so that the case is a little wider in one direction but slimmer in another?
nathanjaker
You mean where the PSU is currently mounted?
That's what I initially had in mind, maybe moving over the PSU to make room for the rad on that wall, but looking at it again it seems maybe unlikely.
I love that this case supports dual 280 at 18L though! Apologies if this was mentioned somewhere else in the thread, but does the "BIG2MAX" support ATX PSUs?
REVOCCASES
REVOCCASES
1,146
1,065
www.revoccases.com
I tried that during design stage but the current layout is a bit more space efficient.
Currently it only supports SFX-L and SFX but I could make a version for ATX PSUs. This would take away some compatibility though (e.g. no top fan, less clearance for the side panel rad, ...)
nathanjaker
Understood. Would screw holes for an ATX PSU fit in the current designs or would the shape have to be revised?
Also, is your posting of the "Rev. 1.0" in the "resources" section the same as the build you showed in this thread on March 18th:
280mm AIO support
Or is it the BIG2MAX? I'm at a school and might be able to get access to a machine shop, so I might try to use this case as a way to learn about some of the tools there.
REVOCCASES
REVOCCASES
1,146
1,065
www.revoccases.com
Cutout and screw holes for the PSU have to be modified. Also the position of the power switch as it would be blocked at the current position by the ATX PSU. Holes for the top fan could be removed.
The files I uploaded are for the "standard" version (my build I showed here).
If you want to make your own BIG2 case DIY: The round vent holes are easier for CNC machining. But you can also just take my files and modify to your liking. That way you can also learn a bit about CAD software.
The aluminum profiles I'm using are pretty common around here. If you can't find the exact same size, some similar ones would also do.
If you don't have access to a press brake to make the GPU bracket you can just use some loooong standoffs.
Nero
60
64
Few pics of the current setup (pardon the dust, just moved everything is a bit of a mess atm)!
With the 3090FE in there currently, I also have a 6900XT MERC 319 (340mm long!) and it fits snugly but perfectly as well.
This case is so good for high performance systems. No GPU compromise, a 280mm AIO is more than enough for all high end CPUs, and the top 140mm with the elevated feet create a bit of a wind tunnel. Only thing I need to complete it is a white power button but @REVOCCASES is on it :)
REVOCCASES
REVOCCASES
1,146
1,065
www.revoccases.com
Nice setup! Next to that huge screen, the BIG2 looks almost tiny 😅
A bit jealous I must confess, especially that you got a RTX3090 and 6900XT 🤩
Nero
60
64
Haha because we can't travel and all I've been doing is working for months on end, now I ended up with a lot of disposable income and decided to indulge myself!
Reactions: REVOCCASES
nathanjaker
What do you guys think about a version of the BIG2 with focus on watercooling / custom loops?
  • Dual 280mm rad support
  • Traditional layout without riser
  • Mounting space for reservoir / pump
  • <=20L volume
  • Open source and DIY friendly or BTO
That would be awesome! It would be great if it could be the same or smaller than an NR200, that's the nearest thing in my mind. I also wouldn't mind not having dedicated space for a pump/reservoir, because I could use a Barrow pump/block/reservoir combo, but maybe that's just me 😄
How would this one compare with the BIG2MAX?
REVOCCASES
REVOCCASES
1,146
1,065
www.revoccases.com
With an traditional (no riser) layout and aluminum extrusion profiles it's difficult to get below 18L with two "normal sized" 280mm rads plus fans. You'll also always end up with some "dead space" so my idea is to put that space to use for an reservoir plus pump (or combo).
Not tying to make the smallest ever dual 280mm rad case but something affordable with good overall compatibility.
So that would also be the main difference to the BIG2MAX where you would have to choose your custom loop components very carefully.
