[Random] Help with a PC-fan home improvement mod
skisendr
Hi everyone! I was wondering if you guys had any advice or ideas on executing a small home improvement project.
I live in an apartment that is heated with radiators, and unfortunately, we only have one radiator that's heating the living room + kitchen of about 800 sqft.
I was thinking about putting an array of pc case fans (let's say ~ 5) blowing air across the radiator to better extract heat and output it to the rest of the apartment, powered by a standard wall socket.
Do you guys have any ideas on how I could hook up 5 or so case fans to a wall socket power source?
Thanks so much!
steelfractal
21
an easier solution and savning youself a lot of hassel could be get a tower fan and point it as said radiator or a indoor Electric Space Heaters or a oli radiator that you can move around to where you need it
