I have a quick question about cooling capacity on rads.
Lers say I make a case like the Corsair One where there are no fans on the rad. Only 1 exhausting out the top making negative pressure.
If I have one 280 radiator with all the air going through it, would actually adding a second radiator with no more exhaust fans, would you increase cooling capacity?
My theory is no. wouldn't it cut the cfm in half if you used 2 duplicate radiators? It should Increase the amount of time for it to heat soak or equalize.
So in my mide it would handle spikes better with 2 rads vs 1 but not dissipate more watts of heat.
Any help would be appreciated.
Lehman
Lehman
