PURE PC 2.0 (e-atx + sli + 1500W @ 25 liters
duniek
55
156
dimensions
400x200x315mm ~ 25 liters
top/bottom/psu panel - 3mm stainless steel
motherboard panel - 2mm aluminium
profiles - solid alu 10x10mm aluminium
total weight (case only + handle + rubber feets) about 1,65kg
build in progress of course - will be finished in next 2-3 weeks I think
CC Ricers
2,175
2,447
Nice extension of the original idea. How did you stick the I/O shield to the motherboard?
Zuuk
60
88
Nice little behemoth you got there :cool: your crypto miner towers are cool aswell. I like the raw look of the towers, purpose built machines.
Reactions: rosinbole
jtd871
1,166
848
If I'm not mistaken, there is no SATA cable as the drive is NVME and slots right into the mobo (M.2 slot).
Unless you're referring to the device plugged into the SATA port in the lower left of the photo.
blackstar2e
please tell me, how to make a custom sata data cable :D
that's the only cable missing in my build^^
are you going to sleeve the psu cables?
duniek
55
156
you have to buy crimping tool - but for one cable not worthto do that
better to order from someone
as 2,5" ssd/hdds need only 5V i made also simple cable for it
in this build I will make them but with angle sata plug
Reactions: Mtthwmths
NateDawg72
393
284
I love how you're making all your cables :D that's awesome. Nice chassis too
What crimper do you use?
I tried a cheap one and I couldn't get the hang of it - either would crimp insecurely or crush the pin. I have a better crimper now but need to get some pins to try it out more
duniek
55
156
I use mdpc x crimp tool - cost less than 50euro - my only regret i bought it this year, if I know this will be that easy to make custom cables I will buy it few years ago
also instead AWG cables i am using 1mm electrical 100% copper wires
