The Fractal Design Kelvin T12 has the pump built into the block. I don't know if the included radiator can fit (definitely not with both fans), but the whole system uses standard G1/4 fittings so you can use a different radiator.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
