Log PSU requirements and Alpha Cool Eiszapfen Quick Release Help.
MrVonGrumble
I am building a Custom loop in the ncase m1 with the following specs:
AMD Ryzen 9 5950x (Pre ordered)
Zotac Trinity RTX 3090 (Got really Lucky.)
ASUS ROG STRIX AMD Ryzen X570-I
Crucial Ballistix 3600 MHz 64GB
Samsung 980 Pro 1TB
Samsung 970 Evo Plus 2TB
Samsung 860 EVO 4 TB SATA
XSPC TX240 Rad
EK PE 240mm Rad
EK-Quantum Vector Trinity RTX 3090 D-RGB - Nickel + Acetal
EK-Quantum Vector Trinity RTX 3090 Backplate - Black
EK-Tube ZMT Matte Black 16,1/11,1mm
Barrow LRC 2.0 Water block Integrated 17W Pump AMD.
So I have a spare Corsair SFX 750w will this be enough?
MrVonGrumble
So what's the difference between these fittings because I am slightly picking my brain. Ones a Bulkhead and the others are different what do these do? Which ones are the best to buy?
So I have a spare Corsair SFX 750w will this be enough? Or shall I Get the SFX-L 800W from Silverstone?
Regards,
Teletubby89
79
56
750 more than enough if it's the platinum, i ended up getting the barrow fittings ( quick release ) £20 a set each really impressed, all in my ncase. Only waiting on my ek founders block to come.
