PSU / Asetek AI airflow issue in DanCase A4
joflashstudios
Looking for some advice on my DanCase build.
When installing the GPU, there's very little clearance between the bottom of the GPU and the top of the AIO fan. As a result, I have to spread out the PSU cables as much as possible or it prevents the AIO fan from spinning. However, this introduces a new problem where the fan is essentially 100% blocked by the PSU cables, severely limiting airflow.
How have others resolved this issue?
LoserCard
Thanks for the mention.
To the OP, here is the bracket I sell (note, this is an old picture/version of the bracket):
They move the PSU up about 6MM upwards which helps a ton especially if you are using stock cables.
I sell these for $20 shipped to the US and around $30 shipped internationally.
Also the STL files are posted if you own/know someone with a 3D printer. Here is my selling post on Reddit:
