I have NIB Predator 240 v1.1 that I am interested in using in the future. I know there were issues with the v1.0, but I think my revision was safe from the bad O-rings.
My question is what are the best mods I can do with the Predator 240? I want a more powerful DDC pump, preferably something better built, maybe quieter than what is stock. Add a heat sink. Clean it out, new fluid, new tubes, new fittings (depending on case), new fans...
I mainly need advice about the pump. And if there are any reliability issues I need to correct for. This will either be a Radeon VII AIO or a system cooler for the Chimera MachOne. I'm also considering it for the Ghost S1, as I've read it will fit.
Thanks.
Thanks.
