G.SKILL International Enterprise Co., Ltd., the world's leading manufacturer of extreme performance memory and gaming peripherals, is excited to introduce a new product line of all-in-one CPU liquid coolers, the ENKI series AIO. Named after the ancient Sumerian god of water, the ENKI series AIO is a custom-designed AIO CPU cooler that focuses on high cooling performance by eliminating heat-transfer bottlenecks and engineered to efficiently extract heat from the CPU, through specially-selected low thermal resistance thermal paste, across the custom-tuned convex copper cold plate, and into the high-density radiator via widened, low-evaporation coolant tubing. Available in 360 mm, 280 mm, and 240 mm radiator sizes, each ENKI series AIO includes 9-blade hydro-bearing cooling fans, ARGB lighting, and easy-to-install mounting bracket kits.
Read full story
www.techpowerup.com
Read full story
G.SKILL Announces High-Performance ENKI Series AIO Liquid Coolers
G.SKILL International Enterprise Co., Ltd., the world's leading manufacturer of extreme performance memory and gaming peripherals, is excited to introduce a new product line of all-in-one CPU liquid coolers, the ENKI series AIO. Named after the ancient Sumerian god of water, the ENKI series AIO...
