Hi SFF!
I'm currently conceptualizing a SFF build which I want to make as small as possible. I'll do the case from scratch, but I want to get all the hardware figured and in-hand so I can prototype the case using the actual hardware it'll fit.
For hardware, I've decided on the following:
I really like the idea of the DC/DC pico style PSUs that fit directly on the 24-pin header and at this point I'm expecting to have an external brick anyways.
I wish something like HDPLEX's 160W DC-ATX solution was readily available with ~250W as for now the only option for that style of PSU seems to be Gury's custom made ones which seems to be sort of a hassle to purchase. However, Gury's DIY concept is really cool so I'll probably end up getting one of his PSUs if I don't find a better alternative.
Then there is the HDPLEX 400W PSU, which is definitely a candidate although it involves making room in the case for more hardware. It also has a significant power overhead from what I'm actually going to need.
And finally, I've looked at the KMPKT PSUs, where it seems I would need the combo of the Mini 160 and the Dynamo 360 to power the build, which I guess is even worse as it both sits on the 24-pin and needs an additional device in the case.
So what I'm wondering is if there are any other options I missed? Or if one of the options I have mentioned above would actually turn out to work for the build.
Thanks,
NN
- CPU: Intel i5-8400. Seems like the best gaming CPU one can get at the moment.
- GPU: Some GTX1060 6GB, probably Zotac's mini version. Should be plenty for 1080p or possibly 1440p gaming.
- MOBO: Any mITX board I like the look off which has decent on-board audio.
- RAM: 16GB of 2666MHz DDR4 RAM. Possibly 32GB if I could spare the change. 2666MHz as is recommended by Intel.
- SSD: I'll use an Kingston HyperX 480GB SATA SSD as I already have that.
Thanks,
NN
