Possibly a dumb question - Slim 120mm Fans
Kit
163
75
I was wondering, when using a slim fan for radiators, what screws/securing method do you use as obviously the screws that come with the radiator are either too short or too long?
Kit
163
75
I've bought some SilverStone SST-FN123 fans and 20mm M3 bolts, hopefully the threads match my radiator!
Kit
163
75
Yep, they worked! Not sure why but I thought there was variation on threads
T4iga
I had the issue with my noctua x15s and HW labs black ice nemesis gts 240 rad.
I cimply cut the screws with a hacksaw. Not pretty but it works. Be sure to not cut to short. If you only screw in one fane you can check length etc visually by peaking fromt he open side!
