I'm nearly done selling all my Salvo 400 series cases, which are mITX cases that support full length & width video cards with an SFX power supply. I already have a few ideas about where I'd like to go next with the 300 and 700 series but I don't know which one is more desirable from within the community, so I'm starting a poll here to help me figure out which is something you'd like to see from me next.
300 Series
This would be another ITX case but I'm torn on the direction. It would be an even smaller ITX variant of the 400 series. I would have to select one of the two options and run with it:
1. Air cooled CPU for thin form-factor (~66mm total width) with no support for dGPU. (model: 300)
2. Water cooled CPU cooling (~45mm width and up to 65W TDP) with the option of adding a single-slot air cooled dGPU. (model: 300W)
700 Series
This one would be my choice because it would target around 17 liters of volume while supporting over-sized dGPUs and full-sized ATX mainboards. It would require an SFX PSU and most likely be a water-cooled-only solution. I would try to support AIO products for the CPU, but I might have to allow the option of an air-cooled GPU. This case would also have windows on two sides and support up to a 360mm x 120mm radiator. I already purchased a 1950X to use as the test-fit components for this design.
300 Series
700 Series
