• Updates are afoot! Track our progress, report bugs, and make feature requests in our dedicated update thread. Read more
    Our latest release introduces full-screen post editing, ignorable forums and threads, lazy loading, unread thread icons, and other enhancements
Poll: GPU Cooling in the NCASE M1
Maniac
43
38
I wanted to make a poll to see what type of cooling people prefer in their Ncase M1. And maybe get all GPU-cooling specific discussion in one topic. Now that the improved v6 is coming just around the corner, this might not be an issue.
In my build (https://pcpartpicker.com/b/zGD2FT) the bottom exhaust fans are the ones making the most noise, even tho the temps are quite good and acceptable. Was kind of wondering how I could improve the noise level. Most people don't care about the noise since they wear headphones. But I do, especially when thinking about others in the house XD.
Now there are folks out there that are not impressed with the bottom case vents of the case (v1-v5). I'm no expert so I wouldn't know. Visually for me it looks good. But the question is, are the vents "bad" in a way that it affects cooling or that the fans just make more noise when pressed up against them (turbulence)?
We all know that the "ultimate gpu cooling" is the Accelero III. But for a lot of folks (me included) this might not be an option. I don't change GPUs that often (my last gpu GTX 670 lasted me over 6 years), and maybe one day I would like to use it in another case, perhaps vertically mounted. Also the prices on the new RTX cards is insane, and modifying such an expensive card would be an enormous risk. And I'm not sure how much quieter it would be?
My recently purchased (used) GTX 1080 Ti Strix has only the fans & shroud removed, and added two 120mm Noctuas at the bottom as exhaust. I have even elevated the case with custom feet. Happy with the cooling here (max 73 C on high load), but the noise does get loud sometimes.
I'm starting to think that the noise might be due to the bottom vents? Wondering if it would be wise to dremel out some of them, to get more airflow and reduce turbulence? I cannot press the fans up against the gpu grill, since the grill has some parts that are sticking out and could damage the fans.
Or if I should perhaps turn the fans as intake (since I have AIO mounted at the top as exhaust).
Anyways, here is the poll (forum does not allow us to create one here):
Reactions: Exal and HZCH
Exal
Since you have a gap between Fan and Heatsink, you could try to put plastic sheats on each side to seal the gap and augment the airflow that go trough the heatsink. Like @Nord1ing did here.
An Accelero iii would be nicer looking and would allow you to have lower speed fan for better perf while being quieter :)
About the modifying, i'd say if you just dremel here and there you risk more turbulence. So unless you plan on cutting 2 120mm holes at the bottom, don't do it.
But i wonder, as anyone done that here ?
Boil
852
694
What...? No love for the Raijintek Morpheus II GPU heatsinks...?!?
Dynamite
21
I have a unshrouded Strix 1080ti with Phanteks F120MP fans mounted to exhaust and a delidded [email protected] with NF-A9s on a U9S in push-pull and vented side panel. I find my GPU temps to be excellent and the CPU cooler is quite a bit louder under load than the GPU fans. I also have some feet that raise the case about 10mm over stock. I did bend some of those tabs on the Strix heatsink a little bit to bring the fans a few mm closer and to clear the fan blades, but otherwise a very similar GPU setup to yours. I don't notice any turbulence noise from the bottom panel and I game without headphones most of the time.
Without a vented side panel or top panel for passive intake and both CPU and GPU coolers set as exhaust, my guess is that the 92mm rear fan is not bringing in enough fresh air for your setup. I would switch the AIO to intake with fans pushing through the radiator. When M1AF on [H]ardforums tested cooling in the NCase, he found that with an AIO, intake fans pushing though the radiator resulted in cooler CPU and GPU temps when using an Accelero III and exhaust fans for the GPU.
I've used an Accelero and a Morpheus in the past and they are very easy to mount. I've used them on 6 or 7 GPUs before without ever having an issue. I would consider an Accelero if you're still unsatisfied as it is a much denser fin stack than the Strix and is smooth underneath so there's no interference with the fans. It is also an excuse to reapply thermal paste, which might bring even lower temps/slower fan speeds.
