Log Planning to move to SFF, need help with case decision.
Kenji
Hello!
Finally decided to slowly make the move to an SFF build instead of buying a laptop in addition to my PC. The PC is mostly used at home, but also needs to be able to be taken to work/university in a backpack. As such I thought a small console-shaped case would be best for transporting in a backpack, because it will not tip over randomly while walking with the backpack. Therefore I thought Skyreach Mini or the Zaber Sentry would be my best bets. But the Sentry is not available for buying except for 500+€ on ebay which is a little absurd.
With the Skyreach I am worried about future upgrade due to the limitations with Voltage and GPU size and the new GPUs :x
Currently I only plan to move my current PC with a Ryzen 5 1600 and a EVGA GTX 1060 into the new case, which would not be a problem but I am quite sure I am due for some upgrades in a year or so, considering I use the PC for playing games and developing 3D applications (possibly in VR too) in Unity.
I assume my next best choice would be the Dancase, but I wanted to check if I missed any other suitable cases/options or my worries about the skyreach's future upgrades are unjustified. So I'd be glad to hear your input! :)
n.tesla
117
42
I can imagine a console style case is going to tip over in your bag more than one with a wider footprint as the weight distribution can more easily go one way or the other no? It would however be easier to slide into a laptop size pouch in a bag.
What GPU are you hoping to upgrade to? The K39 V2 with Black Ridge cooler should handle CPUs up to 3800xt/5800x territory or even 3950x/5950x if you fashion air ducts. Granted you're more limited on the GPU front. Although a 2070 or 2060 super itx would be a significant upgrade.
