Power Supply picoPSU 160W
Earthman
Hi, everyone!
I want to build small mini ITX system with 160W picoPSU+192W power brick in Streacom F7C case.
65W CPU - i7 8700
Noctua NH-L9i or alternative
30W GPU - Low Profile GT1030
2*16GB DDR4
1*m2 NVMe SSD
1*80mm fan
+ sometimes 1-2 external USB HDDs.
Most demanding task will be Lightroom and Photoshop.
It will be fine in terms of power and temperatures?
Nvidia recommendation is 300W PSU for GT1030, but I don't understand why, because power consumption is about 30W.
I'm not planing to play with GT1030, but I need it for two 4k displays, and maybe it can give me some benefits in LR/PS with CUDA cores.
It is the picoPSU specifications, but I'm not so good in this details.
robbee
n3rdware
760
1,099
It'll be totally fine. I'm personally powering an i5 + gtx 1050ti with it. The brick is rock solid and the pico just passes through the 12v input, so even heavy loads on that rail won't be an issue.
Reactions: Earthman
blubblob
103
127
While 180W is in all likelihood more than enough for your needs, I would be careful with buying the PicoPSU you linked the specs of.
It lists a max load of 8A on the 12V rail (8A*12V = 96W). If that rail is fused for that spec you'll have a bad time with it, as a modern pc pulls most of the power from that rail.
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
It's max constant load.
It's's just what the mosfet is capable of. These things aren't fused that I am aware of.
Earthman
Can you explain a little bit more? I'm not so good with electrical details.
Also, I'm found this tread on reddit
https://www.reddit.com/r/sffpc/comments/6bd0w8/my_high_end_mitx_hackintosh_kaby_lake_pascal/
This guy using i7 7700 (65W) + Quadro P1000 (47W) with that 160W picoPSU and 192W power brick.
