This build log isn't anything remarkable really, but I decided that since this will be my first SFF build, I'm going to have fun with a topic. I'm not doing anything fancy, although I plan to use components with LED lighting (without putting a window in) to see what that looks like. The specs are pretty good on paper, too. I'll be reusing some components I bought last year.
I like playing games, but I also like doing creative work for fun (digital art, programming and hobbyist game development). I'm also at uni doing a lot of CS work and programming at the moment. I decided the Ryzen 1700 was a good match for the mix of stuff I like to do. I won't be dragging this computer around a lot, but I like to have a smaller system so I have the option of easy portability in case I have to leave my home for a long period of time.
Hardware & Junk
I'll be reusing my 8GB RX 480 which I bought last year. It's a reference model with blower-style fan, which might be helpful with the temps.
I've got a Ryzen 1700 CPU that I would like to overclock a little, and I'm using the stock cooler since it is fancy enough. I bought some Noctua NT-H1 thermal paste to move the CPU over (it'll be my first time using thermal paste, I've not bothered overclocking in the past, or removing stock coolers).
I'll be reusing my 240GB Intel SSD and my WD Black 1TB drive. I bought these mid last year, so no need to replace.
One thing I didn't put in the above picture; I've got 16GB Corsair Vengeance LPX RAM (2x 8GB sticks) @ 3200mhz C16. It was the most affordable, but on my ATX board I was only able to get it going at 2933mhz using the standard XMP profile.
Some other junk; a Panasonic UJ-265 bluray drive for my NCase (I have the black optical slot model, version 5.0), as well as a slimline sata to sata adapter to hook it up. I've also gone and bought 2x Thermaltake Riing 12, orange LED version. They are designed for both small spaces and radiators, so it'll be interesting to see how that works out. I plan to just blow air in through the side panel and see how that goes, but frankly I hardly know anything about sensible air cooling configuration.
Orange Lighting Experiment
The lighting in my case will be orange, and will come from the Thermaltake fans, the RGB CPU cooler, and the LEDs built into one side of the Gigabyte motherboard. I'm not planning to have a window. I'm hoping it will glow like a lamp, with the light spilling out of the side panels and underneath the case. Will it look any good, or will it be an ugly monstrosity? Stay tuneddddd.
The cartoony NCase image at the top of the topic is exaggerated. The LED fans will probably be obscured by a dust cover, so how it will actually look is unknown.
My Progress Log
15th July 2017
I am waiting on my optical drive and the sata adapter, as well as my power supply. I have everything else. I will probably have to add the optical drive at a later time because it looks like it will take a couple of weeks for the adapter to get here. I have no more news to share at the moment. D:
19th July 2017
My PSU has arrived, but still waiting on the optical drive. I started the build and I try and take some crappy images of the lighting in an un-modded case. Click here for the full post.
22nd July 2017
Optical drive arrives from China! Very well packaged, but I can't test it yet, as I am waiting for my slimline adapter. Click here for the post.
27th July 2017
The slimline adapter arrived. Blu-ray optical drive is installed and working! See a GIF of the drive ejecting discs in my main post here.
12th August 2017
I talk about the issue of having high pressure fans and what that means for dust falling down into the case from the top panel (hint: it isn't an issue). See the post here.
