Opinion for my first mount
montajesff
I want to build a computer with this case and I would like to know if you see any incompatibility with the list that I have created:
https://de.pcpartpicker.com/list/cryW4d
I have this doubt:
1 . Would you put another cooler in case, if so, which one would you advise me
Thanks!
CPU
Intel Core i7-10700F
CPU COOLER
Noctua NH-L9i chromax.black
MAINBOARD
Gigabyte Z490I Aorus Ultra
RAM
Corsair Vengeance LPX 16 GB DDR4-3200 CL16-18-18-36
SSD
Samsung SSD 970 EVO 1TB
GRAPHIC CARD
GeForce RTX 3070 Eagle OC 8G
CASE
Dan Case A4-SFX V4.1
PSU
Corsair SF Series SF750 80 PLUS Platinum 750W SFX12V
montajesff
Before I have not remembered to say that I am also interested in knowing if you recommend any change in the assembly or the components to make it as silent as possible, thanks!
montajesff
While I wait if someone can tell me if the previous mounting idea is correct and that they would improve, I have listened to you and I have mounted another computer:
https://de.pcpartpicker.com/list/GKZrDc
The doubts are the same:
1. You would improve any component that is incompatible or that changing it the computer is more silent
2. Would you put another cooler in case, if so, which one would you advise me
Thanks!
CPU
AMD Ryzen 5600X
CPU COOLER
Noctua NH-L9a-AM4 chromax.black
MAINBOARD
Gigabyte B550I Aorus Pro AX
RAM
SSD
GRAPHIC CARD
CASE
PSU
Shrink Way Wielder
2,223
2,272
Build looks good, only thing I will mention is the Gigabyte is the only B550 itx board that does not have the usb type c connector. The MSI has a custom CPU cooler backplate that won't work with the L9a so if you are looking for a board with the usb c header consider the Asus.
montajesff
I did not know about the gigabyte board connector, do you know if the ASRock B550M-ITX / ac also has this same problem connector
Tashi
49
You can get a 3600MHz RAM for the same price or maybe even cheaper than 3200MHz RAM, and well Ryzen loves faster RAM.
You could also save some money by going for the non OC version of the Eagle 3070 and OC it yourself. If it's available for you that is.
Tashi
49
Do you plan to upgrade the GPU later on to a model that consumes more power? For the 3070 you can get the 600W PSU, if the price difference isn't big keep the 750w though.
daddelbud
81
I dont have good experience with the L9a even with fan duct i hit 80 easily while gaming. Im going for the axp-90 now
