On off switch on S4M
Penguin
40
It should work. I'd try to find one with shorter cables though. You could probably find one at your local electonics/electricity store if you don't want to wait (might need to put the wires on yourself, which is easy). Otherwise, @Josh | NFC sells his beautifully sleeved switch on his website, which also has cables of a more fitting length for the S4M.
