I just bought one of these case fans for my S4M-C. The fan is too thick for the S4 Mini. The side panel with not screw back on correctly and at max speed the fan blades are rubbing against the Noctua L9i cpu cooler. I guess I'm going to have to buy the Scythe 120mm x 12mm case fan. I should have checked with you guys first to see if a 15mm chassis fan would fit in the S4M-C.
Chuck
Chuck
