Production No more sandwich. W19. Up to 360AIO and custom loop. Up to full size 3-slot gpu. DDC pump. Ready for uncompromise watercooled in 10.5L console case.
Which kind of case to send to production first?
  • Total voters
  • Poll closed .
SammyXXM
230
387
anthecase.com
RYZEN 3400G Linpack 30 min
SammyXXM
230
387
anthecase.com
Can u maybe put picture of side panel a little bit closer so we can actually see better panel side....looks sick btw
This is not a final mesh, just to check the airflow through the sides. This one too dense, increases temp + 6 ° C. Tomorrow get another one sample.
As sample for starter line:
Sample for the rest of the lines:
SammyXXM
230
387
anthecase.com
Oh, sorry for the late reply, a lot of news:
Completely finished with the fourth prototype.
Pre-sales start next week, in the first week, payment only by bitcoins, then by cards.
Now the case is slightly over 10 liters, but there are many improvements:
a new size: 430x356x67mm.
Component compatibility has been significantly improved:
VGA fullcover waterblock & PCB compatible with 360 rad:
All reference FE.
Asus ekwb 3090 release.
Also with the alphacool specification:
RTX 3080 TI
Gainward GeForce RTX 3080 Ti 12GB Phoenix (471056224-2379)
Palit GeForce RTX 3080 Ti GamingPro
INNO3D GEFORCE RTX 3080 TI ICHILL X4
INNO3D GEFORCE RTX 3080 TI ICHILL FROSTBITE
INNO3D GEFORCE RTX 3080 TI ICHILL X3
INNO3D GEFORCE RTX 3080 TI X3
INNO3D GEFORCE RTX 3080 TI X3 OC
Zotac GeForce RTX 3080 Ti AMP HoloBlack
Zotac Gaming GeForce RTX 3080 Ti AMP Holo (ZT-A30810F-10P)
Zotac Gaming GeForce RTX 3080 Ti Trinity (ZT-A30810D-10P)
Zotac Gaming GeForce RTX 3080 Ti Trinity OC (ZT-A30810J-10P)
RTX 3080
Zotac GAMING GeForce RTX 3080 Trinity (ZT-A30800D-10P)
Zotac Gaming GeForce RTX 3080 Trinity OC (ZT-A30800J-10P)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXMPB)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXPPB)
Inno3D GeForce RTX 3080 iChill X4 10240 MB GDDR6X (C30804-106XX-1810VA36)
Inno3D GeForce RTX 3080 Twin X2 OC 10240 MB GDDR6X (N30802-106XX-1810VA34)
Inno3D GeForce RTX 3080 iChill X3 10240 MB GDDR6X (C30803-106XX-1810VA37)
Palit GeForce RTX™ 3080 GamingPro (NED30800191A-132AA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3080S191A-132AA)
Galax GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NN)
KFA2 GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NK)
Gainward RTX 3080 Phoenix
Gainward RTX 3080 Phoenix GS
Galakuro NVIDIA GEFORCE RTX 3080 GG-RTX3080-E10GB/TP
RTX 3090
PNY GeForce RTX 3090 XLR8 Gaming EPIC-X RGB, 24576 MB GDDR6X (VCG309024TFXPPB)
Inno3D GeForce RTX 3090 iChill X3, 24576 MB GDDR6X (C30903-246XX-1880VA37)
Inno3D GeForce RTX 3090 Gaming X3, 24576 MB GDDR6X (N30903-246X-1880VA37N)
Inno3D GeForce RTX 3090 iChill X4, 24576 MB GDDR6X (C30904-246XX-1880VA36)
Zotac GeForce RTX 3090 Trinity, 24576 MB GDDR6X (ZT-A30900D-10P)
Palit GeForce RTX™ 3090 GamingPro (NED3090019SB-132BA)
Palit GeForce RTX™ 3090 GamingPro OC (NED3090S19SB-132BA)
Galax GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/ (39NSM5MD1GNA)
KFA2 GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/
Gainward RTX 3090 Phoenix
Gainward RTX 3090 Phoenix GS
Galakuro NVIDIA GEFORCE RTX 3090 GG-RTX3090-E24GB/TP
Custom ddc reservoir 100ml. (sold separately).
Improvement radiator compatibility with ekwb 130 mm wide (non compatible with most of VGA in 360 rad full custom loop mode).
Up to 40 mm thin radiator.
Up to 4x2.5" in maximum watercooled config (recomended ssd, no rubber amortisation).
Houdini
156
83
of course, but I think it would be more rational to use this case with 360 rad custom loops, especially with 3090 FE
I actually don't think that's true. The FE cooler is crazy beefy and on a open bench can almost reach watercooling level (see jayz2cents vid about thermalpad swap)
So in a case where the 2nd fan can pull in air and exhaust it on the other side it should do amazing.
That being said, do you have pictures of the "backside" (the one without fabric)?
Also I noticed on all pictures the fabric is on the left side, do you plan to put mesh on both sides (😍)? Or is back/front swappable?
thelaughingman
1,413
1,566
FE stock cooler can reach WC temps on open bench/case but it's crazy loud - I know cause I have a 3090 FE with the ZS OC v1
SammyXXM
230
387
anthecase.com
Both grilles are fabric, but if you plan to use the case in horizontal, can order ordinal metal grill for bottom.
Ventilation scheme for D17 was in first post archive, W19 slightly difference, but keep main principe direct throunflow:
Houdini
156
83
Was just doing some math and something seems odd:
You say the new dimensions are 430x356x67mm. Let's say we put the case vertical, then 430mm is the height.
And I assume all I/O (PSU, MB, GPU) should come out the back of the case.
ITX needs 170mm.
A Corsair SF750 would need 120mm.
That leaves us with 140mm for the GPU. A 3090FE is 135mm + space for PCI connector + space for the 12pin power.
All of this assumes zero space between the compontens which is not possible.
I don't see how this can fit, can you please elaborate?
DrHudacris
918
1,720
ITX needs 170mm.
I'm also interested in this, but I will note that most GPU dimensions include the connector in the height measurement. Some weird manufacturers will include the PCI bracket itself in height measurements but that is the exception.
SammyXXM
230
387
anthecase.com
ITX needs 170mm.
Yes, the components are packed very tightly, I had to tinker:
3090FE with real (i hope) dimensions (really huge thing, some design changes need to be made) :
Reactions: NinoPecorino
