Production No more sandwich. W19. Up to 360AIO and custom loop. Up to full size 3-slot gpu. DDC pump. Ready for uncompromise watercooled in 10.5L console case.
Which kind of case to send to production first?
  • Total voters
  • Poll closed .
Vir
71
61
Good news guys. The project is alive. After months of hard work, I finally found the optimal design. Pre-sale will open within the next month . Be in touch ! And the highlight is the incredible new cooling system - reversible cooling. It's gets kind of crazy ! So simple like AIO water cooling, but no pump, no leaks, no water ... exclusive. The work went on for many months.
A celebratory dance is in order.
Skarum
108
88
  • Haha
  • Love
Reactions: Vir and eedev
SammyXXM
230
387
anthecase.com
I'm interested in the W19 as well! How does one help fund? How to contribute. Do we have any prototype videos? Any more info on the novel high efficiency cooling solution?
D17 starts first. The fund will be collected through indiegogo. Videos will appear on the site shortly after the launch. Information about cooling not yet available due to patenting process.
cennis
66
50
Interested! Is the W19 meant to support watercooling the GPU? Any renders?
W19
GPU size up to 330x130x63 (in 240rad mode or with air cooling) or 217x130x63 (in 360rad mode at full power)
130mm height is not sufficient to water-cool even 3080 FE due to the terminal at the top which adds ~25mm height. Maybe the EK block could work with G1/4 on the side, but that might exceed the 217mm length.
Lakimakromedia
27
130mm is on pcie side, EK has terminal od rad side.
2070 with block has 180mm, so it's less than 217mm. But more on side with pcie, BCS there is terminal. I saw lately slim terminal from barrow. Maybe this is solution fol older rtx. 30xx series should be fine.
SammyXXM
230
387
anthecase.com
W19
Unfortunately, there is a lot of outdated information in the main thread. After preodrer start, all information will be brought in line with current specifications
SammyXXM
230
387
anthecase.com
W19
SammyXXM
230
387
anthecase.com
I wan't to buy the W19. If that secret cooling tech is available for it aswell I'd be very interested in that too
All cooling technologies have long been known and are very limited by the laws of physics) All that remains is to manipulate their combinations and the ingenuity of the inventor. Separately, the cooling system will be available in classic form factors e.t. 120mm, 240 , 360... But do not expect miracles, the efficiency is higher by 15-20% compare to watercooling. The main feature is no water, leaking, resirvoirs and no noisy pump.
Runamok81
Runner of Moks
Jul 27, 2015
445
621
troywitthoeft.com
Any chance we could siphon some more information about that new cooling solution?
Houdini
156
83
W19:
Will Arctic Liquid Freezer II 240/360 AIO fit? total thickness with default fans is 63mm (38 rad+ 25 fan) or do we need slim fans?
