Production No more sandwich. W19. Up to 360AIO and custom loop. Up to full size 3-slot gpu. DDC pump. Ready for uncompromise watercooled in 10.5L console case.
Which kind of case to send to production first?
  • Total voters
  • Poll closed .
Ezzoud
28
Can the D17 fit a 360 rad with a 170mm gpu? Rtx3000 series have all pretty short pcbs so we might get a 170mm gpu waterblock.
yimg
On the D17, it looks like the PSU is set up to poke its AC plug out the top of the case. Is this intentional? Note how the SFX standard seems to put the AC plug along the long side of the PSU.
NinoPecorino
Tweezer Squeezer
506
515
that's not an sfx psu in the render
yimg
Except now I realize the PSU I linked is a lot longer than anything that could fit in the case. It seems like there's a very real power limit to the D17 - I couldn't find anything close to the 750W recommended for a 3080 build in flex ATX.
NinoPecorino
Tweezer Squeezer
506
515
there are higher rated units available in flex-atx and flex-1u. look up "7760b".
JDuval
93
166
If you want testing with lower TDP CPUs (I have a 5600x), I could do the D17. Have everything else required for your ask.
Cool concept, I like it.
murda
FWIW, this is exactly the type of case I've been looking for (I know I'm late to the party). Nothing against sandwiches, but this is the really good stuff. I'm interested in the D17 in the "120mm radiator. Up to six 2.5 hdd/sdd" format. Really hope you can pull this off!
SammyXXM
230
387
anthecase.com
Good news guys. The project is alive. After months of hard work, I finally found the optimal design. Pre-sale will open within the next month . Be in touch ! And the highlight is the incredible new cooling system - reversible cooling. It's gets kind of crazy ! So simple like AIO water cooling, but no pump, no leaks, no water ... exclusive. The work went on for many months.
