Log NFC S4 mini brickless build Maxsun RX550 4 Gb + i9-9900KF delid die + Alpenform Black Ridge
edgefull
Hello everyone. I used to have two cases: ncase m1 and Lazer 3d LZ7. Finally, I decided to build a computer in an nfc s4 mini case!
At the heart of my build:
  • ASRock B365M-ITX
  • Intel I5-9400F i9-9900KF delid + polish copper IHS (Collaboratory liquid pro + Noctua HT-2)
  • Noctua L9i
  • Gigabyte GTX1060 6 Gb mini DELL AMD WX3200 (Noctua HT-2)
  • 2 x HDD 2,5 mm 1 + 1 Tb
  • m2 nvme by Kllisre 128 Gb
  • 2 x 8 Gb, 2666 mhz by Gloway
  • HDPLEX 400 W DC-ATX
  • AC-DC 400 W
  • Sleeving cables 18 AWG black
  • Button DIY 16 mm blue led
  • DIY GX16 cable (maybe?)
edgefull
I have several problems. The hard disk rests against the radiator DC-ATX 400 W ... Upward shift is impossible due to the fact that the power button is at the top.
I had to fix the hard drive with tape. Hopefully Josh sees this and moves the disc mounting holes inward.
The second problem is that it is necessary to move the video card upwards by 10 mm.
I did not find any drawings of the cover plate for connecting monitors. I will have to make a drawing myself, where the holes for the monitor connectors are offset by 10 mm up.
Perhaps I was looking badly and the drawing is freely available. :D
edgefull
Hi, is this a typo? Or did I miss the arrival of a new GPU?
Hi, I mean the 6 gigabyte version! Therefore, the number 6 in the title.
Thank you for your reply in my post!
I assembled the power cable yesterday! Purchase links:
PET sleeve 8 mm $0.69
GX16 3 pin connector $0.47
HI-End Schuko male plug EU version 24K Gold Plated $7.00
Super soft silicone sheath wire 0.5 mm 3 core $1.06
Heat Shrink Tube Kit $1.33
Finally assembled a cable!
I also ordered a shorter button. I'm thinking of shifting up DC-ATX 400 W.
Reactions: eggDK
edgefull
I replaced the 92mm graphics card cooler with two 92mm coolers from Noctua.
I also removed the bracket to make the model in Auto CAD. A new bracket will be laser cut! This is required to create a brickless build with Gigabyte GTX1060.
Robotanv
26
Hi.
Good luck with the build. I recently finished my S4 Mini and the GPU part is a bit tricky. Did the same as you.. replaced the stock cooler with noctua fans but also had to cut down the heatsink to get it to fit! I don't know how to 3d print but I'm sure that would have made my life easier!
Reactions: edgefull
edgefull
So, update. My graphics card is dead. Currently I have purchased an intel core i9 9900kf processor and a graphics card from dell amd wx3200! I hope to start building soon!
