Hello,
I am in pursuit of a setup that is all water cooled and has a slim CD drive and is SFF of course. In general I would like it to be as small as possible.
In my research, I kind of was set on the silverstone SG06 and I had seen all water cooled setups using this particular case, such as this setup: http://www.overclock.net/t/541767/club-for-those-with-beastly-matx-itx-rigs/8290 The only particular reason I was set on this case was because it was one of the smaller cases that had decent airflow while having a cd drive and water cooling capabilities. There where smaller all water cooled setups, but I am also trying to make a SILENT AS CAN BE build, which means thicker radiators and fans ultimately, as smaller setups, like the node 202 scream loud to keep cool.
I could be wrong, but I think the Ncase m1 might be the case for me, it as a slim cd drive and support for 240mm radiator, though I wonder how thick a radiator and fan I can get away with.
I am completely entrolled by the hd plex 400W PSU, but the adapter it comes with only seems to do 330 watts. Can anyone recommend something that goes higher? Here is what I am talking about. https://www.hdplex.com/hdplex-internal-300w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html ---- If this doesnt work out, I will probably just order a Be quiet PSU.
So in short I am trying to make a small and quiet as can be setup with a slim cd drive. Any advice? I wish the case was shorter, I only want to use a mini-itx ryzen board with a gtx1060.
