Discussion Need a new project
Diamorif
211
105
I'm looking for a new case to build in and was hoping someone might know if a case that's interesting/has compatibility with a 210mm GPU in the 4-6 liter range. I've already done builds in a K39, a Dan A4, and Salvo S402 and have been eyeing something like a Skyreach 4 mini. I have a Zotac 2070S mini, as well as a HDplex 400 kit, and am kind of interested in a case that can utilize these parts, but not a huge fan of the smaller console layout (S402 is a console-style case that houses my main rig). I have just about every SFF cpu cooler under the sun and ill more than likely be going for either a R5 or R7 (my 3700X may make its way from my Dan once I get the next gen R9 chip for my main pc).
Any suggestions are greatly appreciated.
SFF Watercooled
399
172
5L Skyreach 4 Mini with 2070 super mini and same HDPlex:
Velka 5 rev 2.0, 270mm long GPU, 4.94L, 47mm CPU cooler height:
Velka 7 rev 2.0, 286mm long GPU, 5.95L, 47mm CPU cooler height:
SGPC K55, 305mm long GPU, 6.5L, 55mm CPU cooler height:
Vir
71
61
Alternative config for the S4m build: a G-stick 600w and the Zotac RTX 3070 Twin!
Diamorif
211
105
according to the latest post, you can order it from his discord. And isn't the twin edge too long for the S4?
Vir
71
61
It is, but it has a front grill which is not part of the PCB or heatsink. You can make it fit by bending it.
