Cooling NCase M1 with 240 XFlow rad
Darket
Hello! To those who own a Ncase M1 I have a question about if it would fit a Xflow radiator in on the TOP side. I plan to do a proyect like this guy did (see partpicker) but with cross flow. The Standard Hardware Labs GTS240 is 278mm while the GTS 240 Xflow is 292mm and would be great to have room for it
Can you check it? thanks!
paulesko
402
308
Up there there is no room even for a 15mm thick fan. that guy has done some serious mods to the backplate of the case. That motherboard is like....50 mm lower than in the original case. Are you aware of that?
Thac0
21
Also, with the increased width that's common of the current generation of GPU's, there's a very narrow selection of water-cooled gpu's that will fit and still be able to get on a side panel.
Darket
Yes. he made a lot of mods but cooling was much better than with bottom rad. Still, with the raf on top, he placed regular 25mm fans which add to better cooling
