+1 but for V6 (are they the same clips?)
When I packed my M1 V6 in a DSLR carrying suitcase (well padded), I guess the pressure of it laying on its side was too much for the clips and I broke 2 of them. Fortunately it came with 2 extra clips in the box, but I fear I may end up breaking more as I'm taking it on my travels frequently. I'm glad they are very easy to pop in and replace at least.
I'd also like more of those flat screws used to secure the side radiator bracket and various other things that need a flush flat screw, I don't think the V6 came with any extras. (although it came with many extras of the other screws I won't use!)
Clip + screw packs would be great!
