Key components:
Gigabyte Z370N WiFi
Intel i7-8700T 35W TDP
Samsung NVMe 960EVO M.2 256GB
Gigabyte GTX 960 (ITX size version)
BCM94360CS2 in an M.2 adapter
noctua NH-L9i CPU Cooler
HDPLEX 160W DC-ATX Power
Parvum Systems Modding Cubes
This one-off project is nearing completion but is stalled as I test different panel options to obtain best cooling.
I have fabricated the 4.4L case from 6061 aluminum plate and sheet stock with the idea of sending the final parts out for bead or sand blasting and anodize.
As seen here the system is happy until I overload the external 130W AC to DC brick. The brick shutdowns and that is that. I may switch the GPU to a GTX 1050 or purchase a 330W brick.
In this project I have added a folding handle on the top of the case, cabled the HDPLEX 160W PSU out to the bottom panel (clearance issue mounting to the MB), and added a version of my sliding light pipe/power switch/reset switch.
Neil
