So, this is the current culmination of my small form factor habit. It all started in January 2018 when I downsized from a Core V21 to a Cougar QBX. Since then I've moved around, tried out the DAN A4 SFX V2 (fantastic little case), then moved back to the QBX for a short time before finding this NCase V5 on eBay.
And some background on the build.
The CPU was an eBay special. It was already binned, delidded, cleaned up with the STIM removed and replaced with liquid metal and the copper IHS. It cost me £430, which was a fucking steal if I do say so myself. I was quite happy with the 9600K I was previously using, but a man just couldn't say no at that price.
The RAM is a holdover from when I was running a Ryzen 1600 in a DAN case. I removed the heatsinks to better fit a 545LC in the case and I really like how they look with the ASRock motherboard. They've been running absolutely fine ever since removing the heatsinks at 3200mhz/C14.
The CPU cooler I've had it since I downsized to the Cougar QBX and always liked the look of it. However it's on the list for upgrading because needless to say, even with the delid, the 9900K can still smelt metal. I've left it running at 4.7Ghz all core for now since it won't come close to throttling for my current use cases but I'm looking for something better and quieter.
Currently waiting on custom cables to arrive, but I'm quite pleased with the cable management for everything apart from the USB header.
SPECS:
i9 9900K delidded with the stock IHS replaced with a Rockit Cool copper IHS.
ASRock Z390i Phantom Gaming
16Gb Team group Dark Pro 3200mhz
Gigabyte Windforce OC 2080Ti with the stock cooler replace with an Accelero III
SF750
1Tb Crucial MX500 M.2 SSD
1Tb Samsung 860 Evo 2.5" SSD
Noctua D9L along with two NFA12x25 fans and two NFA12x15 fans
PICS:
SPECS:
SF750
PICS:
