My first SFF build - looking to pick up a GPU to finish it up
bigdumbface
Hey whats up , new to the forum. stoked to be here and work on my new build! used to have a stormtrooper case... so this is a very welcomed improvement
my scope: i do a lot of Adobe suite (Ps, Ae, Pr) and want to get more into blender and C4D, and of course do some gaming sometimes.
appreciate any advice and all constructive critique! thanks in advance
plans:
- need to save to get a GPU (have an old one in it now as a temp) ideally a 2080ti or something close
- realized my 500gb OS NVMe isnt as fast as it could be, will replace that soon...
- plan to update the fans on the Kraken to something more quiet.
- will update the 2.5" SSDs just for working storage
- want to update the power button to something a little more slick
current setup:
NCASE M1 v6 case
AMD Ryzen 9 3950X 16-core, 32-Thread Processor
Asus ROG (X570) Crosshair VIII Impact, AMD, AM4, Ryzen 3000, (Mini-DTX) SFF
CORSAIR VENGEANCELPX64GB (2X 32GB) DDR4 3200(PC4-25600) C161.35V Desktop Memory -Black
WD Blue SN500 250GB NVMe Internal SSD - Gen3 PCIe, M.2 2280, 3D NAND, Up to 1700 MB/s - WDS250G1B0C
Crucial P1 1TB 3D NAND NVMe PCIe M.2 SSD - CT1000P1SSD8
(2x) Samsung 840 EVO 250GB 2.5-Inch SATA III Internal SSD (MZ-7TE250BW)
WD Purple 8TB Surveillance Internal Hard Drive - 7200 RPM Class, SATA 6 GB/S, 256 MB Cache, 3.5" - WD82PURZ
CORSAIR RMX Series (2018), RM650x, 650 Watt, 80+ Gold Certified, Fully Modular Power Supply
Innovation Cooling Graphite Thermal Pad – Alternative to Thermal Paste/Grease (30 X 30mm)
NZXT Kraken X52 240mm - RL-KRX52-02 - AIO RGB CPU Liquid Cooler
ARCTIC F12 Silent, 120 mm 3-Pin Fan with Standard Case and Higher Airflow, Quiet and Efficient Ventilation
Noctua NF-A9x14 PWM, Premium Quiet Fan, 4-Pin (92x14mm, Brown)
bigdumbface
I only just heard about this recently. How likely do you think it will be & when. I’m dying to know what the spec change will be.
2,201
2,215
Nvidia just postponed all announcements from GTC, which was when many people were expecting them to launch the first (enterprise/HPC/AI) versions of Ampere. Consumer versions typically launch later; last time around it was at Gamescom in August, with retail availability of the highest end SKUs a month later and lower end SKUs trickling out over the following months.
bigdumbface
good to know thanks!
