I have this card and was wondering if anyone has gotten this card to fit in the NCase M1? I haven't gotten the case yet but wondering if I'll have to get a different style 1070 Ti for the build.
Pretty much none of the MSI Pascal cards fit in the Ncase. The card is 140mm wide which is the absolute limit of the case, the power connectors are at the top of the PCB and you have no way to plug in power.
This is official GPU specs "Height: 140mm at mid-card, 130mm at rear corner, 125mm at front corner (if over 280mm long)" the MSI is 140mm both at the front and the back, so it isn't just the power connectors that don't fit. Necere has also stated that that connector is even too thick.
Yeah, the PCB on those MSI cards extends the full 140mm, and the PCIe power connectors aren't recessed, leaving essentially 0mm to the side panel. Those low profile adapters are still 7mm tall, which is 7mm you don't have.
