msi trident 3
Sidewise
I have a MSI Trident 3 Artic White edition that comes with a msi gtx 1070 aero, does anyone know if the gtx 1080 mini will fit if i want to upgrade?
tinyitx
2,279
2,338
Assuming the 1070 Aero inside is a standard one, its dimensions are 175x129x37mm.
A Gigabyte 1080 Mini is 169x131x37mm. So, it is just 2mm taller. Judging from pics, I would say it will fit.
And, I think the warranty will be voided when the case cover is opened.
br3nd0
307
297
It might well fit but I'd almost guarantee MSI won't recommend due to greater power draw beyond the brick provided with the Arctic. That and yeah you might void warranty. I could be wrong but check in their forums to be sure.
I love this rig though, it's a groovy little piece!
tinyitx
2,279
2,338
Checked a few 1070/1080 Mini cards and it appears an 1080 will draw roughly 20-30W more than an 1070 under load.
So, Sidewise, you might want to check how much power your current system (with 1070) draw under load and see if there is a spare of at least 30W before reaching the capacity of the PSU.
