Motherboards - Thin Mini-ITX
Discussion in 'Wiki' started by drojasxlt, Mar 22, 2016.
  1. drojasxlt
    drojasxlt Caliper Novice
    Thread Starter
    So I went ahead and created a "Thin Mini-ITX" category under Motherboards and added a couple of T-series LGA 1150 boards from ASUS.
    I'm curious as to what data points users would like to see for these boards in the info boxes, in contrast to the normal ITX boards.
    Examples:
    Mini-ITX: ASUS H87I-Plus
    Thin Mini-ITX: ASUS Q87T
    confusis likes this.
  2. BirdofPrey
    BirdofPrey Standards Guru
    #2 BirdofPrey, Mar 22, 2016
    With their intended use being AIOs it might be relevant to mention whether or not there's an eDP port, the standard only requires LVDS.
    Also an internal power plug is relevant.
    edit: also, M.2 is having a bit slower penetration of the market from the looks of things so mPCIe might also be a good thing to note. (from the picture, the board you linked has 1 half length and one full length slot, but one of those could be mSATA)
    Also only some Thin ITX boards come with a PCIe slot which is relevant
    SeñorDonut and drojasxlt like this.
  3. iFreilicht
    iFreilicht FlexATX Authority
    Jup, all of that. Also, the Gigabyte boards also have a WIR of 12-19V instead of the usual 19V, which is very interesting and important information not available in the manuals or product pages of those boards, just in a single press release on the Gigabyte homepage.
    SeñorDonut likes this.
  4. aquelito
    aquelito Master of Cramming
    Silver Supporter Piccolo PC
    #4 aquelito, Apr 6, 2017
    Some more info regarding the on-board DC barrel connectors of current Skylake boards :
    Brand is Singatron, as per Intel guidelines.
    http://www.singatron.com.tw/ftp/3C/Singatron-DC.pdf
    Gigabyte H110TN : 5.5mm DC connector seems to be the 2DC-G213 reference and is rated for 10A @ 20V.
    Asrock H110TM-ITX: 7.4mm DC connector seems to be the 2DC-S060 reference and is rated for 10A @ 42V.
    EDIT : Intel Q77 and H61 boards technical info specifies higher ratings :
    • The board can be powered through a 19 V DC connector on the backpanel. The backpanel DC connector is compatible with a 7.4 mm/OD (outer diameter) and 5.1 mm/ID (inner diameter) plug, where the inner contact is +19 (±10%) V DC and the shell is GND. The maximum current rating is 12 A.
    • Internal Power Supply – the board can alternatively be powered via the internal 19 V DC 1 x 2 power connector, where pin 1 is GND and pin 2 is +19 (±10%) VDC.
    Josh | NFC, Biowarejak and Ceros_X like this.
