Hello everyone! If you like a bit of a read, this first post is for you! If you're more the pictures only type, you'll probably want to wait or subscribe for as parts roll in. ?
This is going to be my first (on SFF.net) build log, and using the soon to release Thorzone Mjolnir. It'll feature some light mods to most of the components, and some custom wiring and sleeving. It'll be used mostly for gaming, but very rare streaming, video and photo editing, and occasionally some 3D rendering/CAD. The parts selection is to make something fit my budget well, as well as get a certain aesthetic I'm looking for, with performance that will hold up for a few years. It's planned to be very monochromatic, with mostly black and silver anodized aluminum (or powder coat/cerakote) metals as accents. Some of the parts I'm waiting for release, as well as debating some others. It'll have some RGB though I don't often use it, it's kind of fun to play with every now and then. The color will mostly likely be off most of the time, and mostly either white or red otherwise.
Case: Thorzone Mjolnir R
For those that don't know, I'll be using a Thorzone Mjolnir. It's a 9.7L ITX enclosure, with a sandwhich style lay out. I plan to use tempered glass panels, but if the cooling is not sufficient I have also ordered it with their "performance" panels that are air-flow panels. I've ordered the case in silver for the exterior. It's exterior measures 209mm tall, 131mm wide, 354mm deep. I plan to have the back panel reanodized in black to match the motherboard rear I/O and GPU I/O nicely.
Processor: Intel Core i9-10900F
I'm choosing the i9-10900F and Z490 platform over Ryzen because most of my "heavy loads" will be games, which Intel still holds a slight edge on. I won't need the iGPU, so, naturally the "F" variant of the CPU is a good choice. Cheaper, and will be ever so slightly cooler. I'll leave it at stock speeds, but maybe with a slight undervolt.
Motherboard: ASUS ROG STRIX Z490-I Gaming
This board has basically all the features I want, and the aesthetic to match. Though I do have some plans to do some mods with either anodizing or powder coating for a custom look.
Memory: Corsair Dominator Platinum RGB
I've always been a big, big fan of Corsair Dominator memory modules. They always have had that look I really like. I debated hard between the regular DDR4 "Dom-Plats," and the RGB models for some time. The thing I like most of the older models is the silver anodized heat spreader at the top. While the RGB model uses a zinc heat spreader, I believe I can have a local shop powder coat the zinc for a real seamless and custom look. A 2x32GB kit is what I'm looking at; as on my laptop and current desktop I've gotten the RAM usage up to around 26 or 27GB or so. I don't believe the difference in speed is necessarily worth the cost, so I'll be going with the "base" model kits at 3,200 MHz and C16 (16-18-18-36) latency.
Graphics Unit:
For a graphics card, I'll be using a NVidia RTX 2080 Founder's Edition. I was able to find a brand new RTX 2080 for around $600 USD. It was a fair deal. Which is fine. I disliked the Super series having a large reflective plate and green accent on the bottom of the card. It fits the build aesthetic I'm aiming for perfectly with it's silver aluminum cooler and black accents.
NOTE: Since originally buying the 2080, the 3080 has released. If I can get a FE 3080, figure out the pin-out, make some custom wires off the PSU directly to it, and re-anodized the copper-y colored exterior casing bits to silver, I'll likely pick up one to replace the 2080.
Storage: WD Black SN750 2TB
I have had great luck with Western Digital before, and given their reviews it seems their SSD's are no joke either. I'll be going with a 2TB NVMe drive as the primary drive for the computer, and another 2TB (or maybe larger, if they make larger capacities) later on if I decide I need more storage space.
NOTE: The Samsung 970 Evo Plus is a very strong contender and has gotten very price competitive, something to consider.
Power: Corsair SF600 80+ Platinum
The SF600 80+ Platinum is realistically the best power supply you can get in a case this size, while still staying true SFX size, and not going over kill with a unit I wouldn't make use of. The 750 watt unit was alluring, but, I doubt this system will pull more than maybe 450-500W from the wall at full load anyways. I plan to replace the fan in the power supply with a Noctua NF-A9x14 HS Chromax fan. I'll remove the fan grill to help reduce noise output even further, and I have plans to do a full set of custom cables.
Cooling:
This system certainly sounds like it has potential to run how, so I went with some of the best choices for cooling out there as well as keeping the system relatively quiet and low-pitched in tone. I'll be using a Cryorig C7G cooler with a Noctua NF-A9x14 HS Chromax fan (this will also match the PSU fan on the same side) for the CPU. As far as case fans, two Noctua NF-A12x15 Chromax fan's to pull air into the case should be enough to push air through and cool it sufficiently.
Some extras/items were previously mentioned, but here's the current planned list of mods:
- Custom cables (all black sleeving, custom lengths for perfect bends, with aluminum cable combs)
- IC Graphite Thermal Pad (for the CPU cooler to help keep temperatures down in the long run vs. reapplying thermal paste every year or so, may apply to the GPU as well)
- Either aluminum plating and anodizing to the memory top-bars, or some powder coating to match the silver of the build
- PSU fan replacement
- Motherboard heatsinks anodized in "clear"/silver
- Fan shrouds to on the rear for aesthetics, also anodized
- Phanteks Halos Lux Digital RGB fan frames, on the 120mm fans, also anodized in silver
- Possibly tint glass side panels
- Anodize rear case panel to black
- D-RGB lighting strips
That's it for now, I'd love to hear some opinions so far if you read through! In the mean time, here's some decent shots of the parts I already have collected thus far.
Graphics Unit:
Cooling:
