Hello @Kmpkt ,
Do you perhaps offer a cable that has molex that can be used with the dynamo mini?
My case has two HDD backplanes and they require molex to fuction.
On the sfflab site it showed "Outputs: 22-pin, SATA/MOLEX, 4+4 EPS, 6+2 PCIe " so I thought there was a molex connector on it.
I thought about using a cable that goes from SATA to molex but I can only find cheap cables..
Thanks,
Sander
Thanks,
Sander
