ML05 Home Server
DrLeroy
Noob Saibot
175
109
Hi Guys,
long time lurker here, but never really been big on posting to forums, but COVID Isolation and all, I figured why not start!
The first one from me is my home server, mainly for plex(storage is on a DS415+), a few VM's for work etc.
Its an ML05 from Silverstone, along with their 450w modular SFX unit.
The components are a bit of a mix as I recently changed around my setup to took my CPU and mobo combo from my main machine after an upgrade.
CPU: R7 1700 (stock speeds)
MB: Asus B350-i Strix
RAM: Corsair LPX 2600mhz cl14 2x16gb (can't get it past the 2600mhz, its a pretty crappy kit tbh)
GPU: Quadro P600
SSD: Boot: WD Green 240gb m.2
VM Storage: RAMSTA(cheap junk) 500gb Sata
Cooling: CPU - Noctua L9a, Case Noctua Redux 80mm PWM x2
Hopefully have this one back up and running soon, as its to replace my old 2400g based home server that was in an InWin Chopin
lowkey
35
The first build 2014. Later i added some watercooling with 160mm (2x80mm) Radiator on the right side.
At the moment i use the case for HTPC behind the TV. Almost the same config without any hdds.
