Prebuilt minisforum EliteMini BOX X400 - deskmini a300 alternative?
gazpl
27
more information was posted here: https://smallformfactor.net/forum/t...oards-they-do-exist.10304/page-14#post-226244
Video: japanese store: https://store.minisforum.jp/pages/elitemini-x400
If these renders are correct this would be the most compact socketed am4 board i've seen. "thin-stx"?
google translate from the store page indicates that the 4650G option might be limited to 45W
case dimensions are 154mmx153mmx62mm, may provide sufficient height for 47mm coolers => no need for VLP ram with a blackridge V2 +120mm fan?
gazpl
27
This is available for order now at https://store.minisforum.com/products/minisforum-x400-mini-pc (4350g, 4650g or 4750g)
may not be a good base for modding though, as this was their answer to a short list of questions i mailed
1) does it have standard am4 cooler mount
No, not a standard one.
2) if yes whats max cooler height in mm
3) is 4750g supported with high power draw
yes
4) are 5000 series APU going to be supported
nope
5) what options are available in BIOS for voltage, OC.
100V~240V
5,570
4,778
100V~240V
Well, no.
About cooling:
The screw holes look like the AM3 layout. Unsure with this image, a topdown picture of a motherboard would allow to be sure.
