MiniPC Router Firewall
BaK
855
868
Hello
Shortest build log ever but this fanless tiny PC is so cool I think you would like to see it!
It is going to replace my >10 years old Netgear router that often needs to be stopped and restarted. Probably overkill but well...
CPU: Celeron J3160 quadcore @1.6GHz (turbo 2.2GHz)
GPU: Intel HD (max 1920 x 1080)
RAM: 4GB DDR3L 1600
Storage: 36GB mSata
LAN: 4x 1GB Intel i210
USB: 2x 3.0
Size: L115 x D107.5 x H39mm (0.48l)
More on the product page: https://www.aliexpress.com/item/Fan...lgo_pvid=ac0c2d17-5c07-4c09-8e30-35553263e0d0
This is a good opportunity to start setting up my own firewall, I am not settled on the distro yet but it will be PFSense or IPFire probably.
Reactions: Jello
