Log Meshlicious in White
7,425
Not quite done, but done for 2021.
Meshlicious in White;
ASRock Z390 Phantom Gaming ITX/ac
Intel Core i7-8700T under Thermaltake block
G-Skill Flare-X 2x 8GB 3200MHz
ASUS TUF RTX2060 6GB w/ Byski block
Silverstone SX700 SFX PSU with standard cables
Gen3 PCIexpress riser, can't remember where I got it from XD
DDC Pump in Barrow res with EKWB heatsink
EKWB fittings
Corsair 10/13 tubing
EKWB Coolstream SE280
Corsair 140mm Pro RGB fans (RGB not plugged in)
EKWB White coolant
tinyitx
2,279
2,338
Once upon a time, I spent Christmas in Australia. Needless to say, it was summer time there and Santa was wearing shorts doing his ho ho ho on the street. The whole atmosphere was so contradictory to a western (hemisphere) idea of a ''white'' Christmas. But, with this all white Meshlicious, you can have a merry white Christmas.
BTW, are those air bubbles in the tube in the 4th pic?
Reactions: BaK and rfarmer
7,425
The bubbles are just a side effect from the bottom mounted res. Once the pump is running, all that air goes straight into the res :)
@tinyitx I'm in NZ, not Australia.. :p Similar Xmas though - mid summer and overly hot.
Reactions: BaK and tinyitx
tinyitx
2,279
2,338
Yeah, I do remember you are in NZ. 🇳🇿
I did visit your country once many many moons ago. Very clean air. What impressed most in my mind, to this day, is the Waitomo caves.😍
Reactions: confusis
7,425
My DDC pump died (ugh), so I've replaced it with a EKWB 160 TBE SPC pumpres. barely fits under the GPU! (minus the vibration dampeners... pump still seems quieter than the DDC though)
Reactions: TheHig and BaK
BaK
967
958
Already? The DDC wasn't new then?
Nice fit with the EKWB replacement pump!
