Power Supply A Guide to 12V PSU
Thehack
Creator
Mar 6, 2016
2,800
3,650
J-hackcompany.com
There isn't a "200w mode." Like most PSU the output is sometimes temperature limited. It is a matter of it getting the required cooling.
You can try to use a fan from the motherboard header to see if that helps instead.
It may be for some reason that small current draw causes that terrible whine.
I had a 1700 and Rx 460 that ran gaming without coil whine. But that is just my experience. The system probably only consumed 130W.
Reactions: Soul_Est and Lone
PackedPC
Ok I'll give that a try. I'm building a mega compact render server with a e5 2683 v4 & 64gb ddr4 so I need all the power I can get haha probably post the build once I sort out this issue
Thehack
Creator
Mar 6, 2016
2,800
3,650
J-hackcompany.com
Good luck! If it ran fine without coin whine while the computer was on, then more than likely you won't have any issues. Just hook the fan to the motherboard so it only turns on when your mobo is on.
PackedPC
Thanks for the help dude, totally sorted now. Must of been the fan pass through that was causing the crazy whining.
raksan
41
55
While waiting for the case, my mean well 400 running combo with z2-atx-200 in naked form:
raksan
41
55
@Thehack now I have a proper case, Lone L4, and I managed to put all components inside. The case has space just enough to fit the PSU, I'm more than happy with this. And I followed your guide by connecting the 12v from PSU directly to 8 pins cpu power (I only plug 4 pins, leave another 4 untouched) and 5v sata power is from pico psu. So far I used very little wires.
The computer run very stable, I didn't do any benchmark but I play game every night. The graphic card run hot though, but I'll fix it by replacing the heatsink and fan later.
Thehack
Creator
Mar 6, 2016
2,800
3,650
J-hackcompany.com
Sweet! You should post this in the L4 thread if you haven't.
Have you tried reversing the CPU fan? Since both fans are intakes, there are no nearby exhaust for the GPU heat. It may perform better as exhaust, as it seems like your CPU cooler is float type.
Also, I recommend you ground your AC power entry to PSU. Or connect it to the chassis, and check the resistance between the power cord and the PSU is less than 0.5 ohms. Don't want an electrical accident.
NYCesquire
23
55
What sort of voodoo would be required for this to run full-power components like a 250w GPU and 85w processor... fanless? Would you need multiple units? Could you replace the small included heatsinks with much larger ones?
Thehack
Creator
Mar 6, 2016
2,800
3,650
J-hackcompany.com
Are talking about the full build being fanless? If you're talking about just the PSU fanless, you should thermal tape some aluminum heatsinks, and locate it near airflow. You should buy the 400W version, and you should make big attempts to undervolt everything. GPUs and CPUs can have their power reduced by 30% for only 5% performance hit.
If you're talking about the whole case fanless, then fanless is in the opposite direction of SFF as you'd require huge-ass heatsinks to dissipate everything.
NYCesquire
23
55
I can solve the GPU/CPU etc being fanless. I'm asking specifically: How could I get a fanless meanwell psu up to 400 watts? Which components on the PSU would i need to heat sink? Would just doing that be enough? Would I need to run two PSUs to do it?
Thehack
Creator
Mar 6, 2016
2,800
3,650
J-hackcompany.com
In that case you should try for the epp 400 and replace or add larger heatsinks. I'm not sure how much you should engineer for it to be able to cool itself.
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
And it works !! Thanks @Thehack for the nice wire harness for my EPP-400-12. Works beautifully paired with a G-Unique board.
Sorry for the bad quality pic ; phone is broken.
I did not stop there and asked the very knowledgable C_Payne @ [H] to develop for me a custom +12V load switch I had in mind.
Thanks to this small MOSFET circuit (next to the multimeter), anything hooked up to an open-frame PSU is fed with +12V when the system boots.
This way, you avoid to power the GPU with your Meanwell PSU when the system is off.
Courtesy of C_Payne (c).
My successful test with my thin mini-itx system :
Reactions: 0xdec and Thehack
0xdec
That looks great! Do you have a schematic for the MOSFET switch?
chribzzz
I'am actually surprised the epp series work with pc gear that get direct 12v from the ac-dc. The dynamic load spec isn't great right?! (max 1200mv p-p) if iam not mistaking most pc psu's have like a max of 200mv p-p transient response. Anyone who has more info about this?
Thehack
Creator
Mar 6, 2016
2,800
3,650
J-hackcompany.com
I looked into what you mentioned. The only pertinent spec I could find that ATX regulation specs is +/- 5%. Is there a special dynamic load specifications that ATX mentions?
Regardless, the chips also have their own DC regulation. These boards work fine even with regular external ac adapter.
chribzzz
Thanks for looking into it.
So 5% reg is 600mv, these EPP meanwell are one the edge of the ATX spec. For the dynamic load you can search for some PSU reviews on tomshardware.com where they perform transient load tests. (these are not ATX spec but give a representation of the performance) I realy like the idea of less wire clutter but it's probably not that simple to find a good performing 12v supply that's around the 2% regulation like SFX and ATX supply's. Was thinking of a higher wattage build but it makes me nervous if it could wreck your HW. Do you think EPP could perform equaly compared to perhaps a corair SF600?
Stable voltages are good for the longevity of your HW right?
