GPU Manli 2080 Mini?
BlivAK
On the hunt for a waterblock for it. I know it's a tall order.
Reactions: Runamok81
Scott
28
It does look like a Zotac, but Zotac doesn't have a 2080 Mini. I didn't even know a 2080 mini existed from anyone!
W4RR10R
197
196
Without pictures of the PCB, I would be hard to determine, Byski may make one they have made for niche blocks in the past (RX Vega Nano). What country(s)/regions does Manli sell in, I've never heard of them.
Your best bet may be a "universal" water block, which is basically a block for the die and a fan/heat sink for the VRMs. Not nearly as pretty as a full cover block, but basically the same performance wise.
Shrink Way Wielder
2,169
2,197
Byski is probably the best bet, they also did blocks for the Zotac 1070 - 1080Ti minis. Another one to check is Barrow, I recently ordered a block for my Inno3d RTX 2070 X2.
BlivAK
Not a fan of universal blocks, looks ugly AF! lol. I'll wait till one comes else might jump on a used 1080ti mini
W4RR10R
197
196
Why not just get the Zotac 2070 super mini, for litterally half the price and essentially the same performance.
ignsvn
By Toutatis!
Moderator
Apr 4, 2016
1,380
1,223
I bought the Manli Geforce RTX 2080 Mini for my Intel NUC 9 Extreme Kit NUC9i9QNX and now I can play all the latest games with the graphics options in Ultra mode reaching amazing fps!
You can get it at the following link:
https://www.hyperspin-systems.com/products/manli-geforce-rtx-2080-mini
Welcome on board, @rodry4383. Awesome first post ?
Appreciate if you can do a benchmark of temperature, fan speed (and if possible, noise) of your Intel NUC 9 Extreme Kit with that RTX 2080? (To read those data you can use MSI afterburner)
Ideally, you'd want to use Aida64, Prime95, or Intel Burn test for CPU. Heaven or Valley for GPU.
Edit: reason being, I couldn't find a review of it using RTX 2080. All I reviews read before were using RTX 2070.
W4RR10R
197
196
Hopefully with the new NUC they will release higher power gpu in a smaller form factor.
Doubt it, for atleast the near future. With rdna2 and ampere on the way most AIBs are probably working on those and wouldn't make a niche product of an old sku. There is some hope for the new cards though.
