Rather than hijacking @Hahutzy XS case thread with graphics card lengths, I thought it may be better to discuss them in their own thread.
@iFreilicht was talking about the lengths of different cards, the EVGA ITX cards are stated as 173mm on their product page, but from my own personal experience I found that the card is actually longer than that.
The length is actually around 183mm, which is 10mm greater than advertised (as you can see from my uber precise tape measure
). The cooling shroud extends beyond the PCB, I measure the PCB to be 175mm long from the flat section of the I/O plate.
I have also just noticed that EVGA are releasing 2 new GTX 950 ITX models based on the new lower power version without a PCIe power connector, it looks like the new cards also use this same cooling shroud so will measure 183mm in length.
Are the EVGA models the longest length ITX cards currently available?
What would you consider the minimum Graphics card clearance should be if you were designing a gaming case specifically for Mini-ITX cards only?
If for example an extra 5mm of case depth added 0.2 litres of volume to the case, you have to draw the line somewhere.
