I know to search on ebay, however, none of these that I could find are near low enough profile, sorry.https://www.quail.com/
These guys have a configurator that lets you custom spec your whole cable. Hopefully this is helpful. Alternatively there are craploads of these sorts of cables on eBay
http://www.ebay.com/sch/i.html?_fro...+Angle+C13.TRS0&_nkw=Right+Angle+C13&_sacat=0
Keep me in the loop, if you don't mind!I'm in talks with another indie case company about a low-profile angled C13 to panel-mount C14 cable like the M1 currently uses. Got a sample yesterday and it looks promising.
I don't know on pricing, MOQ, or time-frame yet though.
Have you considered going custom?
You could always pair one of those low-profile Tripp-Lite C13/C14 with a mounted C14 connector.
Step 1 (Pick one):
Left Angle
Right Angle
Step 2:
C14
It's super easy to make one.
Best of all, you can make it the perfect length (instead of the long one included in the M1) and you can even sleeve it your preferred color.
The left/right angle cables you supplied aren't low profile.
I agree with @XeaLouS . If you would see the size of the Ncase M1's power connector, you would understand what I mean by low profile. It seems to be far more svelte.Why not? They look pretty small to me, compared to the monstrous angled C13 cables you normally find.
Knowing me, there is no way I can build one well enough to be both low profile and safe!You may have to buy an extension and a socket and perform a little surgery to get it.
Oh man! Thank you! I had no idea that they could be found on the M1's page!It looks like Ncase sells the low profile cable(s) directly on their M1 accessories page for $10.
You can even choose LEFT or RIGHT angle.
I'm not quite sure where else to get one but I think Ncase and Fractal both use the same low-profile cable.
I remember seeing the cable in the Node 304.
The one used in the SG08, like the Tripp Lite cables I linked above are indeed a few mm taller.
When every mm matters in a build, I completely understand.
Just poke @Necere and ask. IIRC the right-angle cables are supplied via Lian Li (who get them from an unknown OEM), but I may be remembering incorrectly.Now... Does anyone know how I can pester Necere into giving me the dimensions?![]()
Did poke him first post, but you can can clearly see no response.Just poke @Necere and ask. IIRC the right-angle cables are supplied via Lian Li (who get them from an unknown OEM), but I may be remembering incorrectly.
Thanks man! Do you have any clue as to when you're going to get them in Stock?Sorry, I don't log in here every day.
The C13 on the M1's power cable is 27.5mm in overall height, and the part that sticks out from the power supply is 13.5mm high. Note that the socket on the PSU adds a bit of height as well, around 2-3mm.
W360 has been working on getting a new supplier for the power cables, since the current ones have had a somewhat high defect rate. No ETA for when those will be available, though. Edit: he tells me we should have them in stock some time in December.Thanks man! Do you have any clue as to when you're going to get them in Stock?
