Hello Everyone,
Wondering if something like this would be possible:
Looking to build a SFF Intel (probably i5-12400) based PC, though I might consider AMD CPU instead. Looking to use a Velka 3 case.
Any recommendations on Intel or AMD side for Mini ITX motherboards that support bifurcation?
Also, looking for the PCIe 4.0 x16 bifurcation cable so that I can connect both a Radeon RX 6400 vid card (I don't need high performance - just a casual gamer) & an old Mellanox ConnectX-3 10Gbit Ethernet card to access my OMV Server at 10Gb.
Also, would there be power issues in this scenario? Since the RX 6400 needs to draw all it's power from the PCIe port & not really sure how much power the ConnectX-3 card draws from the port.
Also not sure if it matters but looking to use Linux most likely (latest Pop OS!) instead of Windows.
Thanks!
Thanks!
