So I’ll be starting a new job. I use a lot of gpu rendering. I have a x299 Asrock mb with 10gbe, the 14-core i9, and 3 1080ti’s. I need to find a good case to use. Right now I have a h500i (I think) it was a matx case, but I dremeled and crammed in a dual gpu & cpu water loop. Using and i7 in that loop and looking to upgrade
I really don’t wanna go huge, but do wanna do water cooling, since I have most of the stuff, just need to expand on rads maybe. Probably two 360’s. Anyone have any case suggestions ? I could go with just 2 gpus if I could find the right case. But priority is small & outtasight. No rgb needed, no glass sides needed. Just good cooling and small as can be.....I have a Cerberus-x but cramming all that in there is tough, I tried once and failed (hence the h500i)
