Looking for a part for ncase m1
Zutko
24
As a name of the thread says, I am looking for a part for my ncase m1. It's a little metal part that sits on the right of the PCI openings ( it's mounted with 2 screws). I'll post a picture in case you wonder what It is I am talking about. I live in Sweden, I'll pay for the post and package cost :) Part for ncase m1
Necere
NCASE
3,284
I call it the PCI access cover. SFFLab is the only source for M1-specific parts, and what they list on the site is typically all that's available. You can try contacting them anyway - Dan might have an extra left over somewhere.
You also asked about the PCI slot covers in your email (really, you didn't need to post and email so many times...) - again, you can ask SFFLab, but these are also Lian Li standard parts, so you may be able to get them through them.
sheepdog43
25
Could also cut one from some plastic/wood/metal or 3d print one.
It's just a flat plate with 2 holes to fit M3 fasteners.
Reactions: Zutko
Necere
NCASE
3,284
Here are the dimensions of the PCI access cover:
Thickness is 1.5mm.
