Hi all, been lurking round a while and decided to join. Big SFF fan, will post my setup later. Looking for some help with case design, I have no clue on what programs to use to design (hopefully a simple one is out then). I'm a fan of the Velka 3 but not a fan of the flex psu, also would like to reuse the hardware i have already. I want to keep it compact.
My thoughts were Sandwich layout. Motherboard is asus b450i 170mm x 170mm. the gpu msi 2060 super aero is 175mm L x 42mm thick x 127mm H. Sf600 psu is 122mm W x 65mm H x 102mm depth.
so sandwich layout but with the psu at the front of the case pull air in through the front panel (will need a power cable extension)
or have it mounted above the motherboard pulling air from the top.
Rough dimensions. Psu at the front. 250mm L x 140mm W x 180mm H
Psu at the top 180mm L x 140mm W x 250mm H
