Discussion List of ITX GPU (with dimensions?)
XeaLouS
180
123
Is there a spreadsheet or such of a list of ITX GPUs with dimensions? Preferably on google sheets for sorting pleasure...
Diamorif
211
105
Not that I'm aware of, but most of the last-gen AMD and Nvidia cards were somewhere between 173mm to 175mm long with fairly standard two-slot height and depth (Powercolor 5500xt to 5700 for AMD and a wide swath of 10XX 20XX and 16XX series GPUs from Zotac, MSI, and Gigabyte). Zotac also makes 2060, 2070, 2070 super, 1060, 70, 80, and 80 ti models that are around 210 mm long (ti is 211 due to a larger second fan). I can highly recommend the 1080 ti mini from zotac and the 2070 minis from Galax (175mm dual-fan) and MSI (173 single fan) for really performant sff builds. Not a google sheet, but hope that helps
XeaLouS
180
123
My case is designed for 170mm and under, so i suspect i'm out of luck. I designed it myself so i guess i could change 4 panels to extend the length by 10mm~ to 180 and gain a bunch more compatibility :S
kotproger
136
131
vk.com
I don’t know about you, but we have a number of stores that have the characteristics of video cards (including the exact length) and allow you to sort by it. For example.
Diamorif
211
105
Nope not sol, I’m just dumb. Standard itx, including the 2070 other than galax, are around 170mm. Sorry dude, not sure what I was thinking
prayogahs
236
343
Hi, see this thread, it has a list of ITX GPUs in the SFF GPU < 215mm Sheet
