Hello,
I just finished moving my system to the 011 Mini. I find having three fans at the bottom feeding air directly to the GPU helps temps a lot.
At the moment I have the motherboard placed in the middle vertical position. The VGA card is being cooled nicely, and there is some distance between the VGA fans and the bottom case intake fans.
I have the option of moving the motherboard even lower which would put the VGA card almost touching the bottom intake fans. Would this result in better temps or the opposite?
Thank you
Thank you
