You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Status
Not open for further replies.
Picked up a Laing D4 for a non-PC watercooling project, but it looks like the bearing surface in the rotor is off-centre causing the rotor to vibrate in operation. Does anyone have a donor rotor from a dead pump?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
